SignUp Now!Steer me in the right direction, i might know how to work on these but im no engine builder. This is why i ask alot of questions.Well the nice thing is that's a very late 85 up RWD block Jim, not an earlier one. You miht want to look in the general section about using the FWD roller lifters instaed of flat tappet ones. Since the lifters are available out of a scrap yard and can be reused all you really need to buy is a roller cam and read up on how to do the swap.![]()
Do you want to go flat tappet or roller Jim? That's the first question. It might be easier to go through email if you're interested.![]()
Did you mark each rod in relationship to the crankpin it came off of?
If by chance you mix up any of the rods and place them on a differant crank pin you'll never be able to turn the crank again. It'll lock up on ya, and you'll have to have the rods and crank machined if you can't find were the rod was originally on the crank. Happened to me with three rods and I spent several days testing until I got the rods on correctly were they were removed from.
No. It's just the rods. Can't mix up the rod caps either. Since you're replacing the pistons you'll have to farm out the work anyway because a press is needed to remove and press the pins onto the rods. The two dots on the rods indicate the direction it should be facing, (towards the rear or front of the engine). The two marks on the oem piston also indicate the direction of were they should be facing.
Holy crap it's Fred!No. It's just the rods. Can't mix up the rod caps either. Since you're replacing the pistons you'll have to farm out the work anyway because a press is needed to remove and press the pins onto the rods. The two dots on the rods indicate the direction it should be facing, (towards the rear or front of the engine). The two marks on the oem piston also indicate the direction of were they should be facing.
