chrisgarrett
Registered Member
- Jun 2, 2004
If the starter is wet, the most commom causes in order of likelihood are:
1. back of intake
2. valve cover gasket
3. turbo oil feed block leaking and blowing back when you drive
4. front cover leaking and blowing back when you drive
5. oil leak at the top of the head gasket from rocker area overflow
If the starter is wet, it is almost surely not blowby or the rear main seal. I know you have a lot of suggests here. Here is mine, which I have used on several Buicks successfully. Go to your parts store and get the UV oil leak detection kit. It consists of uv fluid, yellow glasses and a uv lite. Add the uv to your oil, use a rag to clean the oil off of the engine, put on the uv glasses, start the car and lay under it. With the little lite, shine around the engine and you will see the leak. It will show up as yellow. The uv fluid has no bad affects on your oil.
But before you do any of this, clean up the oil with a rag. Lay under the car with a light and look at the ps valve cover gasket. Is it wet? If not, I'm putting my money on the back of the intake leaking.
1. back of intake
