Smokin'
fgordon
Waitin For The Majic
I have a problem with heavy exhaust smoke after hard accelleration. Once the engine cools, no smoke. This has happened twice and I can't find an obvious cause. It is oil smoke not antifreeze, I can tell by the smell. Any ideas would be appreciated because I'm all out of ideas.....Thanks
Frank
Holly smoke screen, Batman!
Is there oil in your up pipe? (bad turbo seal).
Does your intake manifold gasket have the valley pan on it? (could be throwing oil at the pcv valve).
What do the plugs look like?
Is your turbo bell breather blocked off?
PCV valve stuck?
Bad valve guides?
Leaking intake manifold gasket in to lifter valley?
Heck! maybe on your last oil change, the grease monkeys thought that your alky res was a tank for your dry sump oil system and filled it with 5-30?:eek:
Good luck...
