1turbo6
- Jun 14, 2004
well I did head gaskets on a 3500 mile engine about 6 weeks ago because I thought that was my problem well, it still seems to be smoking oil. I pulled the up pipe off and there is no oil in it or the throttle body. what is the best way to narrow down the search? when I had the heads off the pistons looked pretty dirty(wet cokey oil) I thought it was the gaskets. it does not smoke at start up but I notice it when you rev the car and sometimes while cruising I will see it in the rearview. the turbo did not seem to have any in/out play and minimal up/down play.also exhaust side seemed dry. compression before headgasket replacement was 160ish all cylinders. could it be blowing up through the rings? or valves leaking down? I am running umbrella seals
