SignUp Now!Originally posted by GNSCOTT
......Funny how guys defend a turbo. i can care less which would turn out to be better, i just think the test should be fairly and correctly done> ...................
Oh, so the claim is a half second now. i'm sure it was with the same tune also. Dyno test both with the same ex. housing on the same car, same day, same exact tune then post your results.
Do you want to know if its the GTQ or if its the ex. housing.
Originally posted by norbs
What heads are on your TSM car topgun and what is the flow in cfm ? thanks just curious.
Same tune up, target A/F and timing with both turbos. The times were run at different tracks maybe that is why it picked up so much mph
I am not sure what you are getting at with the above statement please explain
Good that you mentioned felpro, as the felpro data shows i need lower ve numbers, with means less fuel with the gtq then the p-trim. Hence less horsepower ouput. Or is the turbo more efficient? causing this?![]()
