- May 28, 2001
To start out lets say i overheated my trans and melted some parts. Its a built 200 that worked amazing. I had the parts replaced by a local guy in the club who builds trans as well. He just replaced the bad parts, center support, direct drum(or forward drum, not sure) and 2nd gear band. After i put it back in i did not have OD. It sat for awhile because i was mad at it and had a few other cars to work on too. Sothis weekend i pulled the valve body and found what he said to be true, stuck 3-4 valve. Cleaned it out and put it back together and voila, OD again. BUT, now my 2-3 shift is soft and hesitates.
It needs a battery and wont hold a charge, i can jump it but it dies. Its low on gas and its about 7mo old gas at that.
Any thoughts?
TIA, Scott
Any thoughts?
TIA, Scott
