Soft shift BRF
  • Thread starter Thread starter Gary Hairfield
  • Start date Start date
G
Gary Hairfield
Guest
I have an 87 Turbo Limited in San Diego. I bought the car with 127000 miles
on it last winter. The car had a dead fuel pump(not making any horsepower for a long time)
and a trans slip when I purchased it. I adjusted the TV cable and that took care of it while it had no horsepower.
I then put a Fuel pump in and figured out the trans slips under boost(1-2 shift takes 1.5 seconds to lock and 2-3 takes .5 second to lock) everything else is perfect. I finally called Bruce Recently and he sent me a care package (Shift Kit plus 1-2 accumulator Seal and spring
etc, the pressure reg set and a book on this thing. I pulled the pan Last night to do the kit and first pulled the 1-2 accumulator down and found that the seal on the accumulator was shrunk up and not sealing. So I decided to do the seal and the spring set up Bruce sent and try it like that. Well I was amazed that 90% of my 1-2 **** problem was gone.Now the 1-2 and 2-3 shift
lock down in about .5 seconds(not perfect but now close). After living with this for 9 months
I really feel stupid for not jumping in sooner.
So the question I now have especially for Bruce is do I need to go for broke and do all
the work(pressure Reg,Plate etc.) or part to get it the rest of the way.
By the way I put this question here in hope someone out there might benefit from this
info.
also I seldom post but often read and benefit from everyone on this forum and I want to
say thanks.
Gary Hairfield
Go ahead....
Finish the job. It should go from "ok" as you say to "awesome". We can dream can't we? Seriously, try it and report how it turns out. But I bet your smiling........:D
Thanks Bruce
I put the rest of the kit in and it was actually too firm. So I talked to Bruce and
he recommended I take the shift kit shim out of the TV boost valve and try it and it is GREAT!
This car now spins the tire on the 1-2 shift and is firm but not rude when cruising.
This car actually went to my local tranny guy at which nothing was accomplished.
I kept hearing the trans is worn out but I bought the car with the original fuel pump in it and I can assure you it hadn't made any horsepower in a long time so I kept holding out for another answer. I can say that the help I got from Bruce was A+ and worth every penny.
I only wish I had called sooner.
Thanks Again Bruce,
Gary
