That article is very basic and doesn't list all the info needed to give a reason why one may or may not use a solid or a hyd for a particular application. In the case of about 99% of our engines we are springing for ramp not rpm. Also the xer hyd roller lobes they are using are extremely aggressive if analyzed with a solid lifter. The most aggressive hyd lobes are as aggressive as the most aggressive solid lobes also. Solid lifters provide a huge window of advantage in certain applications where stock valve heights must be maintained and spring selection is limited. Hint, hint. If we were lucky enough to have the heads and valve train capabilities to play with that these Chevy, ford, and mopar racers do our engine would be 3-4hp/ci with relative ease.
