some more new billet products.
chris718
E4340 steel billet 2004r band anchor pins,$15.99.Fully cnc machined ,radius added to weak areas,and heat treated to 42 rc.Steel billet output shaft to install a 4l80E transmission in a c5 corvette which comes with the differential bolted to the rear of the transmission and a torque tube up front.Shaft is 4l80E on one side and 4l60E spline on the otherAdapter plate to hook the 4l80E to the original c5 differential.Im working on a lot more and also have the front pump and adapter plate for this conversion,have done 2 already.2004R PANS AND 9 CLUTCH DIRECT DRUM COMING SOON.ARE COMING SOON.
Chris, no idea what any of these things are, it's all Greek to me. Opa!
Under the valve body,It anchors the band into the case.\
With a extremely firm shifting 2cd gear,These can break.
Cheap insurance during a rebuild
