Matt McClung
Hotair guy who owns a I/C
- Sep 18, 2001
Okay, I have a problem. I have injector pulse, and I have crank signal at the ignition module, and I have cam signal at the ignition module. All powers and grounds to the module are good. I have taken the coil off the module and have verified with key on, I have power at the coils, but when I crank I have no coil pulse on the three separate wires to the coil. But as I said before, I have injector pulse when cranking. I know that this would usually mean a bad ignition module, but I replaced it already and the new one does the same thing, except that sometimes when I turn the key on and crank it will spark for a second and the engine wants to start but that is it, no more spark. The new module is a BDI brand from Advance auto, and the coilpack is a brand new AC Delco.
Has anybody had any trouble with the BDI modules?
Matt
Matt
