My calcs for the 18 to 1900bhp are based on a big cube (no bigger than what most are doing), stage II headed, single turbo, alcohol fueled Buick V6 engine with cylinder pressures at a safe max limit. The fuel is being pushed to the limit. Camshaft is a bit wild and the horsepower peaks beyond 9,000 rpm.
Intercooled, of course.
It's my dream engine, if I ever have the money to build it.
Sorry for all the babeling.
I have tried to tune a few big tire cars on roller dynos and have had hte same thing happen.Well we tried to dyno it again today. When the rpms got to 7000 it would spin the tires. Kinda like tire shake. it rattled the switch panel loose from the harness. So now it is time to finalize all the loose ends and test it thursday. I was not ready for was the massive amounts of fuel consumption. Went through 7 gallons in 3 pulls. We are also trying to make a 1/4 mile run friday at VMP, if things go well at benson thursday.
The engine will absolutely make more power than needed to get the job done at 2100#!
One thing we're finding now is that alcohol seems to need more timing than gasoline. 26 degrees seems to be the threshold. Anything less and you start to see the power dropping. 21 degrees and the engine is an absolute dog. Beings that we're in new territory here, I'm not sure what the safe limit is considering it's looking like we're going to need to run 35-40 PSI on top of the 11:1 compression ratio we're starting with to get in the horsepower range we want to be in.
This was kind of a surprise. I wasn't expecting to need to run that kind of boost on this engine but it seems to like it and we're keeping the EGTs way down to keep things safe. We've only cracked 1000 degrees on any of the cylinders once.
BTW, Don.. a page or so back we talked about EGTs and their accuracy vs update time. I talked to the manufacturer of the engine management system who told me it's instantaneous and that the EGTs are monitored only after firing the cylinder.
This system really is on a whole nother level than anything else I've ever worked with including Motec and Autronics. It's strictly a race only setup tho. The data logging capabilities of this unit are phenomenal.. you can really get yourself into data overload quickly with this system. The amount of trims and adjustments in this system are insane. You have gear specific timing tables, gear specific fuel trims, RPM based individual cylinder correction, altitude correction, etc. It's a pretty awesome system.
