turbojimmy
Supporting Member
- May 26, 2001
My trans has been doing this for a long time and I finally decided to get under there and see what's going on. Unfortunately, after looking at it I have no answers.
When sitting on an incline that has the nose lower than the front, the trans basically drains itself. LOTS of fluid on the ground. It's not overfull, and it will drain itself to the point where nothing shows on the stick. When it's level it will leak out until it gets to about the right spot on the stick, maybe a little low.
I thought it was either the TV cable housing or the dipstick tube but I got under there with a mirror and they're both fine. Lines aren't leaking. The pan bolts are all wet which would make me think that it could be the pan seal but I didn't think the fluid should be above the gasket when filled to the right level? There is some fluid above the pan gasket, too, on the front but it could be blowing up there. It does not appear as if the front seal is leaking (and it wouldn't leak while it was sitting anyway, right?).
So you think this is just a pan gasket? Is there any other spot I should check for leaks-while-sitting other than the TV cable, dipstick tube and pan gasket?
TIA,
Jim
TIA,
Jim
