Going through my garage and found some gaskets from a fel pro gasket kit that I didn't use. Also have 5 used pistons, 4 are fel pro's I think, marked .030, other is a replacement. The replacement has 13 miles on it. Brand new box of 4 cam bearings, not sure if new but oil pump gears packed in assembly lube with springs in box with instructions. Also have headbolts, used for 13 miles before motor was torn down for another rebuild, will throw in if someone buys everything.
