Speedometer gears
1952ray
Scrambled Dog
For anyone who cares to know. The 86/87 gn's with 342 factory rear end gear the 200 4r Trans comes with the 11 tooth drive gear orange in color, the driven gear is 30 teeth blue in color. If you speedometer is fast 5+ mph or you go with taller tire's you will need to drop down with the driven gear 29 teeth green in color or even lower. TCI keeps these gears in stock. 662-224-8972
The green 10/black 27 combo is virtually identical to the oe ratio as well if a green gov gear is all you can find...
