spohn tubular front upper control arms, tall ball joints
haywire4130
pair of spohn upper control arms, black powder coated with droop stops, installed but never driven on. they have urethane bushings and an offset cross shaft for more camber adjustability. these won't clear GTA wheels without trimming the ear off the corner of the ball joint pocket (per spohn tech line). $200shipped
pair of new proforged tall ball joints part# 101-10020 $60 shipped
Mounting hardware included?
Sent from my iPhone using Tapatalk Pro
The arms reuse the stock knurled bolts so you can add/remove alignment shims without using 2 wrenches. the ball joints include hardware.
I currently am waiting to replace my badly worn out original upper control arm bushings with new Moog problem solver bushings. I was going this route to keep factory height, factory arms and factory NVH. I have other suspension bits front and back that tightened the car up.
If, instead, I go with these arms and ball joints, how far will the front end drop?
Will I dislike the new ride feel with the poly?
Finally, will these cause any interference with gbody 8" wide aluminum wheels? I run a 265 wide tire up front but shorter.
Thx.
Sent from my SAMSUNG-SM-G900A using Tapatalk
I will take both. PayPal?
