spooling
chops
I have a 61 turbo with a 3200 stall spoolin of the in is horrible :mad: what's size turbo housing should I get ? I really want this thing to come out of the whole like a rocket if I have to race someone it has to be while am already spooled if I race of the line let's just sy:eek:any help from someone very knowledge would be greatly appr:)iciated
what exhaust hsg. do you have and what exhaust wheel? A true 3200 stall shouldnt have a problem spooling 61-XX turbos... any exhaust leaks? Check your tune.... maybe too fat down low. Any numbers?
Don't know the housing or wheel size am pretty new to the turbo buicks I do have an exaust leak on my test pipe but that's after I don't think that would matter maybe am wrong if so correct me right now my car clunked out this morning it started poping and barely made it home and now it won't. Start .but to answer your housing and compressor size they do look pretty small that much I can tell you about turbos:confused:
yeah... figure out whats wrong and why it suddenly died and report back... first get it running right and get some numbers.... a 3200 should spool a 61mm. and yes an exhaust leak after the turbo shouldnt matter, in regards to turbo spool
Definitely double check for any exhaust leaks, a true 3000-3200 should have no problem spooling a 61mm turbo. What chip are you using?
Datar
also make sure your wastegate puck is lining up correctly... Is it the stock downpipe and wastegate, or aftermarket?
