jpwalt1987
- Nov 9, 2003
bison said:I would run zero preload. Jwalt isn't sure if his problem is valve float either.
Well I guess the first thing to do is adjust to zero preload and test it out. I have to test on the back roads because the track is an hour away and only open on Saturdays. Brian, looking at the screen shot on the first page you can see what the converter goes to when I go WOT. Do you think if I could get the engine to Turn 6000 that I would be ok with that power band? Not sure where to go from here now.
