turbobusa69 said:after talking with comp cams, they dont recommend running 26120's closer than 050-060. so i think i will try another spring. i attached the comp cam pdf on the 26120's
http://www.compcams.com/WhatsNew/Files/26120 Beehive Spring2.pdf
comp gave me part number 978-16 a dual spring that they think is a better option. i have ordered K motion #750 springs and will try these this weekend and see how they check out.
I've ran the 26120 down close to coil bind. But with hyd lobes and the lift is theoretical because of the bleed down. PAC 1203 has a much higher rate and works well in hyd rollers with lift up around .600
		 headed to richard clarks dyno asap again to final tune. so for those following this thread, be cautious with the bee hive springs on your roller cam setup. mine didnt like 130lbs seat and 300lbs open pressures they have!!!
