SignUp Now!That book is probably "The Buick Power Source". Many forum members have it. It has been posted in photographic form on the the board many times. And yes, it is a good book to have.Got a pretty sweet stage 2 book too. Has all the engine tolerances, part numbers, casting numbers, break in procedure, etc etc. Would be cool to scan all of it for people to see.
I actually have been speaking with the guy you sold all your stuff to Neal . He seems to be a pretty cool guy . I’m getting some parts off him .Looks like the truck load of stuff I sold to the guy who bought my race car. Congrats on the score!
Neal
It's an On Center motor. The block casting should be 2550153. These are later blocks from the Buick Motorsports program. Since it appears to be an ex Busch GN engine the bore size should be between 4.00 and 4.020" which will give you a good cylinder wall thickness and the option for rebuilds in the future. Once you get it apart be sure to sonic check the block for core shift. The On Center blocks are much better than the earlier castings from that standpoint.
Neal
Yea the ones with the cross bolts are the later ones . So if you wanted to go with a oncenter block those ones are the ones to build . I’m not sure why a majority of ppl are scared of building a on center motor. I think is because everything can’t just transfer over from a 109 block like the stage off center blocks . Imo the on center is the way to go and you basically just by acouple spacers and everything lines up and you are good to go.You definitely know your stuff. And you're right they are all 2550153. What's weird is 2 of the blocks are clearly different. They have different castings and are lacking the 2 side bolts going into the main caps. Yet they are all the same number on the block.
I wasn't much intimidated to build an on-center. But for me the reasons for going off-center made a little more sense to me at the time (2003ish). And it makes just as much sense today to stick with the off-center in the future.Yea the ones with the cross bolts are the later ones . So if you wanted to go with a oncenter block those ones are the ones to build . I’m not sure why a majority of ppl are scared of building a on center motor. I think is because everything can’t just transfer over from a 109 block like the stage off center blocks . Imo the on center is the way to go and you basically just by acouple spacers and everything lines up and you are good to go.
From what I have found people don’t really know how easy it is to go with a on center build . The only tricky part is the intake which isn’t that bad as you can by a on center champion race now a days .
It’s not the conversion to efi I was talking about it’s the whole shifting the intake runners over to fit to a on center block . But like I said champions race intake is a great choice for anyone running production style heads .Not that hard to convert the carbed intake to EFI.
