I'll try to make this short. I've got my Weisco pistons hone fitted in my 153 block, piston to wall clearence at .004. My machinist installed the pistons and rods in the block, and their all above the deck by .010. I bought the block seperate from the rotating assembly. 3.625 crank, 4.020 bore, 6.5 rods. Question... should I machine pistons down .010? Run a thicker head gasket? I'm trying to achieve compression ratio of 9.0-9.2-1. I'll be running GN1's, custom solid roller,etc. I'm not looking for the cheapest solution, I've been building this for two years, just want it right. Thanks, Phil.
