I had sold my first set of sheetmetal valve covers, so I made another set today. I like these better, but my welding wasn't the best today.
I also rebuilt a distributor I bought from J-B Racing. Joe, It's probably good that you didn't run it. When the previous owner welded the reluctor to the shaft, they trashed the top bearing. Also the reluctor was cracked in a few places. I cut it off and made my own cam sync setup using an MSD cam sync kit. PN 2436 http://www.msdignition.com/Products/Distributors/Acc_/2346_-_Universal_Sync_Signal_Kit.aspx
The cam sync kit consists of a magnet and a pickup. I made the round aluminum part that goes on the dist. shaft. It uses a stainless bolt to clamp it in place. The magnet is pressed into the aluminum disc and has a little epoxy to make sure it's stuck. The pickup is threaded through the body below the magnet.
