Brake lines are done.
This is how the cam sync works. The MSD cam sync kit comes with a 1/4" rare earth magnet and an inductive pickup. I replaced one of the upper cam gear nuts with an aluminum nut that has the magnet pressed into the end.
Then I made a bracket that will eventually bolt to the distributor plate that holds the pickup. I can't set the exact position until I get the real motor here.
