I am in the process of collecting parts for my stage 2 single turbo build. Could someone explain what all is involved in converting to a wet sump system on a stage 2 iron block? This will be a on center stage 2 head motor.
Are the oiling systems the same for the ta aluminum block?
What front cover do you use? is it the dry sump style or can a production cover be used?
thanks,
doug
thanks,
doug
