Thinking about selling engine out of car.
Stage 2 engine bored .030 over
JE pistons
All race bearing thoughout
Carrillo Rods
Steel crank
Solid roller cam from DLS
Comp roller lifters
Chromoly pushrods
Stage 2 front cover
stage waterpump
4 stage drysump system w/tank
Clog belt system
J&W SFI flywheel
BHJ SFI balancer
LS1 Starter
Stage 2 heads
Jessel valve train
Inconel exhaust valves
Titaniam intake valves
Comp Cams springs
Fully ported
Buick Motorsport Valve covers
Hogan Sheetmetal intake
160 injectors from PTE
90mm Throttle body from accufab
SX fuel regulator
All braided hose on intake
Applied technology twin turbo headers
2 1/2 exhaust crossover in front of engine
PTE 91.5 turbo with 5 inch Downpipe
Old Tony Dequick 6 1/4 thick intercooler that was
modifyed for 3 1/2 inlet and 4 inch outlet and all
aluminum tubing.
Motor still in car and runs perfect!
Best to date is a 8.32 @ 161 on 22 psi 3000 lbs car
with a powerglide trans
Asking 18k for all above
Just add ecu and go racing
Other Stuff for sale
Old box felpro SFI set up for buick
comes with cable,o2 and 160 injector program installed
Asking $1250.00
Dis4 box(pin switches) with adapter on coil
Cam sensor and 10mm wire set
Asking 400.00
Turbo400 with brake
All stock internal with all racing clutches and steels.
Has deep aluminum trans pan
only use a couple times
asking 550.00
Thanks again
Tony
JE pistons
Carrillo Rods
Steel crank
Comp roller lifters
Chromoly pushrods
Stage 2 front cover
stage waterpump
Clog belt system
J&W SFI flywheel
BHJ SFI balancer
LS1 Starter
Stage 2 heads
Jessel valve train
Comp Cams springs
Fully ported
SX fuel regulator
aluminum tubing.
Asking $1250.00
Asking 400.00
Turbo400 with brake
asking 550.00
Thanks again
Tony
