Stage 2 TT street car
DSCF1299.JPG DSCF1300.JPG DSCF1302.JPG DSCF1303.JPG DSCF1306.JPG DSCF1308.JPG
Designing new fan shroud for lower profile Spal fans, oil can bracket design and built a master cylinder heat shield:
DSCF1285.JPG DSCF1286.JPG DSCF1289.JPG DSCF1291.JPG DSCF1292.JPG DSCF1293.JPG DSCF1295.JPG
Thermostat housing is hitting the IAC housing so I need to raise the plenum, which causes the top of the TB to smack the hood brace (see baking powder playdough mark on said brace........get me a cutoff wheel:
Mike
Mike
My,my you have really got it going on, superb work. Very,very nice indeed .
Installing GNX wheelhouse extensions this week, this solves my problem of the front tire smacking the upper part of the wheel well, mine had lots of rub marks. I bought the kit from member Xray, he hand-fabricates each one, mine fit perfect.
DSCF1378.JPG DSCF1390.JPG DSCF1392.JPG DSCF1394.JPG DSCF1398.JPG DSCF1400.JPG
Mike
Fan shroud fabricated, installed Spal fans, built mounting frame for water tank and insulated. Ran separate oil feeds to the turbos. Need to mount a heat exchanger and run A/C lines. Getting close to handing it off to a pro for exhaust system fab and the initial engine firing and dyno tuning.
DSCF1348.JPG DSCF1332.JPG DSCF1355.JPG DSCF1325.JPG DSCF1326.JPG DSCF1327.JPG DSCF1336.JPG
Mike
Little progress, undercoated the GNX front fender mods, finished closing off trunk, rolled the front and rear fenders, installed the WTA heat exchanger.
Mike
One thing I've noticed building it so far is the stock chassis is as flexible as a noodle. On a M3 or 911 when you jack them up in the front or rear the entire side of the car lifts up evenly, the GN twists like a soft pretzel. I need to have something like this done after the drive train is completed:
These are pics of a GN done by Gary Naughton Race Cars who I hope to turn loose on mine one day.
Mike
Modified idler pulley location to improve belt wrap. Intercooler pump mounting ready, A/C system completed except for 1 hose, stereo components mounting shelfs for trunk completed, new 285/35/18 on 18 x 9.5 Coys. Intercooler brace completed, 1" ID hoses front to back completed, heat exchanger mounted.
DSCF1504.JPG DSCF1511.JPG DSCF1513.JPG DSCF1522.JPG DSCF1430.JPG DSCF1433.JPG DSCF1434.JPG DSCF1441.JPG DSCF1504.JPG
View attachment 292779 View attachment 292780 View attachment 292781 View attachment 292783 View attachment 292784 View attachment 292785 View attachment 292786 View attachment 292787 View attachment 292788
Very nice, great workmanship!!!
Front coilovers, designing the downpipes:
DSCF1536.JPG DSCF1551.JPG DSCF1553.JPG DSCF1555.JPG DSCF1559.JPG DSCF1561.JPG
The tape works well to lock the 3" dryer hose into shape, I'm sending these mock-ups to a fab shop.
Mike
Completed DP mock-ups with 3D printed wastegate exhaust tube stubs for fab. shop to duplicate. Intake mock-up completed as well.
Mike
Stainlessheaders.com fabricated the downpipes and intake tube. I highly recommend this company, they can fab. anything and their prices are unbeatable.
DSCF1679.JPG DSCF1680.JPG DSCF1684.JPG DSCF1685.JPG DSCF1689.JPG DSCF1694.JPG
Mike
Fabbed-up the air intakes, I found a 4" dia. hose exactly like the factory hose, re-enforced with steel wire, silicone. Filters behind the air dams so now I need to install ram air scoops in the air dams to directly funnel the air at the filters.
DSCF1645.JPG DSCF1646.JPG DSCF1650.JPG DSCF1651.JPG DSCF1652.JPG DSCF1665.JPG
Mike
Nice hose, where'do you find it?
