turbobitt
- Feb 14, 2002
Well, Finally decided to pull my motor to inspect and freshen over the winter. I managed to accumulate a lot of street miles(~3500) over the last 7 years. Well things inside looked better than I expected. I thought for sure that my crank thrust would be worn from the transmission pressures but that was ok. I originally thought the compression was 8.5 to 1 but a cylinder poor revealed that it was 8.0 to 1.
Question is, since my combination is probably dated, what would be the things to change ? My ultimate goal would be to run in the high 8's with a full weight car. This is the rest of my engine specs,
8:1 compression
242 dur @ .050, 605 lift
Stage II heads flowing 310 in, 265 ex.
Crappy valve springs(comp 933 with about 180# at the seat)
6.5 Ti rods
3.59 stroke
4.00 in bore
88mm turbo
Not looking to throw money at it but was looking to up the compression a little to help spool. Maybe 9:1 ? Will increase the load on the springs while I'm in there.
8:1 compression
6.5 Ti rods
3.59 stroke
4.00 in bore
88mm turbo
