Stage Ii On Center 4.1 Block $1900
tjc
Nice stage II on center block 153 cross bolted front and rear mains.
It has bush lifter holesand the bore is .030 the block has NO sleeves.
I can deliver to the race at bowling green or norwalk.
block is in michigan my number is 810-300-4447 $1900
Standard bore for a 4.1 liter is 3.965" not 4.0". Still not a bad deal.
Neal
Has the block been bored? Pics of the head side of the block?
Conrad
block f s
Any actual measurements of individual cyl. bore dia., measurement of deck height,lifter bore dia.(bushed or std.)
Has block been windowed.Or any previous sleeves installed??
Any other damage to block??? Rust , pitting , cracks , weld repairs , spun mains... ??? Cam bearing journals ( condition , std. dia.) ?
How long has it been since block has been in use.( running engine assy.)???
Has block been magnafluxed and have cyls. been sonic checked (since last time dis-assembled)?
Original main caps or replacement caps??
Any history of other catastrophic failures ?
Sorry I don't have a bore gauge.
I try to to use caliper to get it close. The bore where 4.027 to 4.029 the main where 2.676 and the cam still has the stock stile bearing in the block. And for the lifters the block was set up for bush lifters I have the bushings there not in the block the bushing size is .845. and for the deck height I have no way to check and I will say it's NOT a short deck block. This is a none oring block There is no sign of any parts braking in the motor.
I was going to use the block till I bought a car with a stage motor in it.
I have had this block for 5 years Jim
