Stage II street turbo for 5" dp question...
we4Mateo
Double you eee what?
My Buick guy wants to turn his car back into a more streetable ride this year and has a turbo recomendation question. His current setup is 270 something inch stage II, fast xfi, heads, solid lifter cam, full suspension, everything basically. He currently has a billet precision 4788 sp cover with 5" vband downpipe. Is there a turbo out there that will feed this thing but still spool better for street use and still be able to reuse the downpipe?
Please advise and thanks in advance.
So he plans on changing cam and torque converter also id hope. He will have to have a fabricator adapt the new turbo to the current pipe. Nothing will just bolt in its place that i would say is a street turbo.
That's what I was thinking. He's trying to get buy with buying as few different parts as possible. Any suggestions on a size though? I thought a 6776 would feed it but he thinks 7676 at a minimum with .85 A/R. He has a 3500 or so stall I think.
I run a GT42-76 with a 5" downpipe on the street. Great street manners, reacts quickly and has enough power to get a Buick motor in the 8's, provided the right parts are in place. I had the matching flange to my downpipe welded to the exh housing of my turbo. I did not cut off the existing flange on the turbo, just welded the 5" flange to it.
What exhaust housing does the GT4788 have? I would assume it has a T6 housing.
Precision sells their PT8884 turbo with a T4 .96 A/R housing. That 8884 appears to be based on a GT4788. You should call them and see if their T4 housing will work on the GT47. It uses a ~4" downpipe flange, but that would be a cheap upgrade that should help spooling tremendously.
Thanks for the pics and info. Beautiful setup!
To make it work even close to how it should he will need a cam, 9.5" ptc, and a different turbo. If you leave out any if the 3 the thing will be a waste. You didn't mention what mph he was looking for. Once you figure that out you can get a ballpark on the turbo, converter and cam. This is about a $4000 changeover not including labor.
Labor isn't an issue, he probably has a dozen or so converters, including two from Dusty, and he knows he needs to swap to a more streetable cam and probably leave the solid lifters. He just doesn't want to buy another downpipe if he doesn't need to do so. He's trapping 153-155 now in a 3550lb car so I know he doesn't want a slug but 140+ should be good. His wife's TA motor traps 138mph on low 20 something psi boost from a 76 but that turbo already has a home and won't work with the 5" downpipe either. I told him it was doubtful he'd be able to use the downpipe over, but I like what ttypewhite has done. I'll pass along this information Friday when I see him. Thanks again.
He could do it on a hyd cam but still needs the correct converter. He
Will need more than a p trim if he's looking for 140+. Any of the
Common Tsm turbos will get it done.
RJC MAKES A 5" DOWN PIPE THAT USES A BOLT ON FLANGE TO THE TURBINE HOUSING MADE OUT OF BILLET TO ACCEPT THE V BAND...I JUST INSTALED ONE... CHECK THE WEB SITE IT SHOWS A PIC AND U CAN BUY THE FLANGE SEPERATE..... JUST TRYING TO HELP?
Thanks!
