Stage Right Trans brake
al shapiro
I while back someone advertised a Stage Right Trans brake for $135 shipped. Does anybody know who this was and if the deal is still available? If not the best place to purchase it. Thank you.
That would be me!
I have some. And will have a few in BG.
Thanks, Brian
trans brake
are they still $135 shipped and do you have a phone number that I can pass on to a friend who is the one that needs it after going for a ride in mine. Thanks
They are still that price.
586-306-9996.
Brian
transbrake install
I installed mine with no problems. The valve body has to come down, drill 2 holes with larger drill bit provided in kit and replace 2 valves. Instructions are really good.
one of the best mods / upgrades you can do, if you are serious about drag racing your TR
transbrake install
the shifter does not have to come out but you do have to remove the center console to change the detent bracket on the shifter (2 bolts... really easy) so when you come out of 1st gear you don't hit neutral. It stops the shifter in 3rd gear position.
