Need feedback on stage 2 project.Like pistons that i need for my build.Here are my block specs.Buick stage2 0153 casting 4.050,block height 9.50,LA Billet 3.590 wide journal,BMS stage2 aluminum heads intake 2.125 exhaust 1.625 46cc comp.chambers,intake titanium exhaust steel,dual valve springs with steel retainers,Jesel valve system,Carrillo 6.5 on center rods with Carr bolts,Comp.Cams roller lifters,Comp.Cams roller cam gross valve lift .577 ADV Dur;261 261 Dur @50 224 224 lob sep 115.0,BMS on center intake converted to DFI,90mm throttle body,T-76 turbonetics ball bearing,96 MSD injectors,Felpro 1026 gaskets.
What kind of HP can i expect with my setup?
Max RPM with my valve train?
Do i need to get titanium retainers or can i use the steel one because i will be using it mostly on the streets?
Need help on piston dish size for my combo because right now i am looking to get 9.171 static compression ratio with 35cc dish.
What is the deepest dish size with block height,rods,crank and 46cc cambers?
