turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
Ok maybe I'm loosing my mind but I cannot seem to get any cooperation out of this car...
I replaced the t-chain, (rotated the engine just to make sure no issues), buttoned everything back up. Primed the oil (70psi)... set the cam sensor twice to make sure I was at TDC then 25 degrees past (Even removed #1 plug to make sure), used the cam sensor tool and followed directions, checked all grounds, all connections, sensors (double checked the cam sensor and crank sensor position just to be safe) and spark plug routing.
No leaks, problems that I can see.
Car cranks but won't fire. Pulled plugs. All wet. Replaced plugs, cranks but will not start. All items were working perfectly before I took it apart. Did not modify any sensors just put it all back like it was supposed to go.
What am I missing?
What am I missing?
