nightowls_gm
- Oct 14, 2006
im having a problem with getting the car to start, i have to stay on the gas when i crank it then rev it a few times till the idel is still, also when driving sometimes it backfires.it does have a new maf,tps,spark plugs with wires.i set the cam sensor at 25 degrees atdc and the tps is at .42volts at idel, all the vacum hoses seem to be in the right place.is there anything else it could be?thanks!!!!:smileh yeah no codes.
