- May 28, 2001
Correct.I can't see the pics ,if i click on the link in any of your posts it says I do not have permission to see the media,so i'm guessing alot of others can't see them either.
SignUp Now!Correct.I can't see the pics ,if i click on the link in any of your posts it says I do not have permission to see the media,so i'm guessing alot of others can't see them either.
have you verified this? this can be a cause of your problemVery important. Make sure all the little cups come out with the stock injectors.
Can't see pic's either, same error message.
The clean plug is likely the cylinder that got the water in it.
RemoveBeforeFlight
Just out of curiosity which cylinder did the clean spark plug come out of ?
update : never mind i went back thru the thread and saw that it was #5
I would check that Exhaust cam lobe very closely as well as #3 exhaust also.
Actually the whole cam and lifters need to be checked well, but pay close attention to those 2.
Also just in case you don't know ,make sure you mark which lifter came off of which lobe and put them back the same way if you plan on reusing them.
Did you find sludge on the bottom of the intake manifold ? A small leak will steam the oil leave a milky slide on the bottom of the intake. It's possible it was just leaking in #5 and going out the exhaust also.
