turbov6joe
Signal 1 J-12
- May 22, 2002
I've been gone for a while and havn't posted here for who knows how long. Anyhow, for those that knew I lost my motor in BG the damage was 2 roached main bearings on the center two. I have the block out getting checked for flatness, new Durabond cam bearings, and some trick oiling for the thrust surface which also had some minor wearing from what I have no idea. Unless it was the cam I lost the lobes on and trashed last winter with just 50 miles of running time, I can't tell ya where the wear came from??? Anyhow, with any luck I should have the motor up and running by mid August sometime. The cam I had in it was fine as were the rod bearings....looks like some HG material got into those 2 main bearings and took them out. I'm hoping to have it ready and have made some passes before Noble, OK. in October. If the first pass of BG is any indication of what the car is capable of, I should be very happy once I get a chance to sort things out. I'll keep you all posted as things progress.
