The quickest and easiest fix for all involved would have been to file the tab off the bearing, I wish I would have seen this sooner.
I mentioned that way back , but no one paid any attention to it .
SignUp Now!The quickest and easiest fix for all involved would have been to file the tab off the bearing, I wish I would have seen this sooner.
This post is not meant as a means of starting a war on this forum however I would never omit the locating tab on the bearing.The opposing bearing with the tab can spin 180 degrees in the mains.The thrust bearing is not keyed to the outer edge of the cap.Relying on bearing crush to locate a bearing is foolish.Why dont we just file off both tabs and see how long the bearing stays in place and how long the motor lives.Anyone whos replaced bearings in the vehicle or with the crank not removed can understand what im getting at.
When Ford started using aluminum blocks in the Cobra Mustang in 1996, they used a different bearing than the iron blocks used (tab on brg located different). It took a couple years for the aftermarket to produce a high performance bearing for the aluminum block. We had no choice but to buy bearings for the iron block and file the tabs off both sides prior to assembly. I built several high HP supercharged modular engines using this method as well with no issues (7000 rpm plus!). When we convert on center Buick rods to off center narrow journal rods, we follow the same procedure. The bearing tab locates the bearing in the saddle for assembly and that is all. That little tab on the bearing will do absolutely nothing to prevent it from spinning. Bearing crush it the ONLY thing that keeps the bearing in its place.
It;s odd that one would be asking for help from the same sort of middleman that marred4life was seeking to avoid. So not to be out done I hereby recommend leaving the main cap off completely from what I'm reading it's probably not necessary if the car never makes it out of the driveway anyway.Overpriced Lou, (the turbo buick god)
Why don't you give this guy some real advice; like Anderson did?
(Middlemen have almost fully been eliminated; since you are lingering in the past here.....)
You get what you pay for! Also I don't think Lou's overpriced for the time and TLC he puts into his work.
I hope everything get resolved with the cap problem Mike![]()
You mean free advise.I don't serve at anyones pleasure but my own. Guys like you that have never spent a dime with me don't deserve my support & have a lot of nerve to expect any. true I have my own loyal customers that I take very good care of.If some of the other vendors feel a need to help guys like you for no other reason than to stroke egos .I say go for it. I would like to have an open debate on how smart it is to give all this hard earned knowledge away for free. What do we have to sell but our experience & time.I bet you count every dime coming to you on your pay check.You see we don't have that luxury.So when some jerk off like you demands vendor support & don't even have the courtesy to call & introduce himself or at least be civil. This is the kind of response you can respect from me.These comments really don't help your business Lou; remember, you're not the only vendor available.
I guess youve proved to me that it works Bill but without anything to locate the bearing in the cap how do you line it upfrom left to right in its bore?How do you stop a first timer from placing the bearing in the wrong position if there are no tabs?I believe the 4.6 has outer lips that locate on the blocks.Is that correct?It would be very(with a 3.8) easy to install the lower bearings in the top and vice versa.
