Blown&Injected
- May 31, 2001
Could too much pressure in the form of a shim between the Throttle Valve Spring and Throttle Valve Plunger cause a trans to stay in 2nd gear when doing a slow and go, as in a fast to slow to 1 MPH, or less, at a stop sign? If I stab the throttle as I pull away, it will pop into 1st.
