I have been fighting waste gate issues forever. I am running a 66mm turbo with a .63 exh housing heavy duty regulator with threaded rod and an after market boost regulator (dont know the brand) Anyway I have always had problems from day one,either way too much boost or not enough could never get a middle ground.
When I was at the track I could only get the car to 19psi and it would barely creep to 20psi around the 1000 foot mark.The car ran 12.00 @116 I tuned the rod in and craked on the adjustable regulator and same boost. I then gave the car a few degrees of timing and got 11.54@116 still 19psi just barely creeping to 20.
I have had the wastegate off and reamed out the whole thinking this would keep it from sticking open. Since the being at the track I have had nothing but issues on the street. It will spike to 19psi in fist and slowly drop off by the time it hits 3rd it is at 10-12 psi. I took off the adjustable regulator and hooked it up tuner style. it would do the same thing but only spike to 15psi in first and drop off. I gave the rod a few turns and same result 15-16 psi.
I think I am gonna take my dp back off ream out another .005 and install a new waste gate from RJC.
I am out of ideas
What are your opinions?
I am out of ideas
