SignUp Now!Might want to replace every vac line under the hood too... ESP the three that run from the turbo to the wastegate.
If you touch a hose and your finger turns black, it should have been replaced 10 years ago.
Give the check valves a blow test too.
Blm on scan master will tell you if there is a vacuum leak. S/b 128 +/- 10 at idle.
A bad PCV valve will put blowby back into the intake, under boost.
Does the intake gasket have the valley cover built into it?
IC clean?
Smoke test the exh. I use a wet rag wad wired over the tail pipeand give her a shot of Seafoam. Watch and see where the leaks form.
Mismatch between the injs and the chip? Inj leaks?
Leak down and compression test?
That'll work!Do I spray the Seafoam into a vacuum line while it's running?
