stock headgasket thickness???
1985GN
Breaking parts
after reading many many threads why is it that i have seen .060 and also .040 im under the impression that .040 has always been the stock size head gasket??? experts whats your take on this and does anyone know if you can get custom size cometics??? i see them in .040 and .060 and thats it
stock 86-87 graphite composite was approx .070
GM steels shim gasket (two thin stacked steels) are approx .037
the cometic multi layer steel gasket is made from two outer coated embossed thin steels (aprrrox .010 ea) and a single heavier uncoated steel center(.020) to make up the .040 gasket
.060 gasket uses two layers of the heavier steel in the center
far as i know they also offer a .090 gasket if you have to make up for a heavily milled head
looking at summit i found only the .040 gaskets listed in various bores , no other sizes
looking at cometic site this morning (cometic.com) they too list only the .040 gasket in various bores ,
ive been running the .060s that i get through jack cotton , he still lists the .060 gaskets on his site
