SignUp Now!Originally posted by turbo9
will the small injectors couse the head gaskets to blow?
Originally posted by Quick6'n'-K.C.
its not the injectors that are making the head gaskets blow-
its the high boost and DETONATION caused by too much timing and not enough OCTANE-HTH
i have a n 87 gn with a t44 and champion cnc ported heads. i am running 24 psi and just blew my second set of head gaskets. i am sending the heads in to be o ringed but is the stock injectors too small and causing this?
Originally posted by SuperSix
I smell a troll..
i just bought the car and am looking for some help thats all. if that is too much to ask i guess i can always go buy a mustang.
Originally posted by TurboDave
Well, yes, but it's the injectors that are the root cause of these problems.
It's bad enough running the TE44, with the stock injectors, but then push it up to that high boost level, AND run that through ported heads.
I run a TE44 through stock heads/motor and MSD50's, and they're pushing over 80% duty cycle at 25# of boost. I'm quite sure if I added a set of ported heads into that mixture that the fuel requirements would increase exponentially, and my duty cycle would probably start pushing up into the high 90% range.
That car has to be running HORRIBLY lean and detonating like CRAZY.
Originally posted by turbotwister
the troll statement is uncalled for!!!!!![]()
you people need to be smacked!!!!!!!!!
what the hell did this guy do to you?????!!!!!!!!!!
there isnt a law against not knowing something!!!!!!!
obviously you people grew up not knowing anything!!!!!!!!!
did it ever occur to you that this gentlemen wants to learn what he doesnt know?maybe thats why he is asking?![]()
maybe you should ask yourself why understanding isnt part of the way you think IDIOT !!!!!!!!
HAVE A NICE DAY!!!!![]()
