strokethis
- Feb 22, 2012
can i take both screens out of my stock maf?
SignUp Now!Since when does a stock MAF have two screens?
The one in front (the one it needs and is supposed to have) is there to straighten out the air flow so the sensor will sample accurately.
The GM unit I have has one screen, and that looks like all it should have EXCEPT that now I look more closely there are some faint scratches that MIGHT be from somebody taking a second screen out....![]()
It's definitely a restriction. It was enough of a restriction to limit one application to about 470whp/24psi on a 60-1. With the wastegate wired closed. I converted the car to xfi and just left heavy tension in it and it wrapped the needle round the gauge rhe first time i hit it. It takes a lot of compressor and ex energy to overcome the stock maf with screen(s) over 600hp. Spoolup was greatly improved removing the mafs also. Richard Clark has probably posted the flow somewhere but it appears that it can't flow much more than about 500cfm before it creates a huge pressure drop at the inlet. I once dynoed my car with a t72 and made 559whp through the maf with a screen. The inlet hose compressed like an accordian under power. Not good for efficiencyTurboTnZ06 said:I went 130+ mph in the 1/4 on the stock maf, screens in. I don't think its a restriction. For example I can see through the maf screen, but if I hold up my air filter I can't see through it..
jiho2 said:With the '87 type, how do you keep the wires aligned so they look like one screen?![]()
Well that's what I'm saying, Hot Air is all I know, I can't speak to MAFs for IC cars.
What confusion I've had on this issue seems to boil down to this difference in the design. The Hot Air MAF has its screen embedded in a thick plastic frame. I mean molded in solid, no way to separate it.
(I can't distinguish layering in the wires, so I call it one screen.)
