Strange thing happened after coil and module change
TurboTdr3.8
I replaced my coil and module and after I changed it I noticed the Caspers Cam sensor Cap led lite was on steady while running and blinked only while cranking , before the old coil and module the led lite on the sensor was blinking while running all the time , has anyone had this to happen , the motor seems to run the same blinking or steady so it was a mystery why this happened . Anybody got a clue
im still trying to understand why anyone needs that cap
1. You need a new cam sensor cap to replace a defective cap or as a spare,
2 You need to set your cam sensor timing,
3. You don't have a cam tool,
4. You can tweak the injector timing to compensate for big cams.
Hope this helps you understand...
