SignUp Now!Yes I did try undoing the screw using a 6 point socket and believe me it's stuck in there pretty darn good.
If this method sounds ok, I will try just PB blaster first and see if that doesn't help. And if not then add heat.
Why not just replace the calipers? They're only about $20 each. The time you spend screwing around (pun intended) with the bleeders, isn't worth it.
No contest for time saved! If you want to get back to driving your car, just get some new calipers.
