Recently i changed over to vacuum brakes from the powermaster. I installed a new brass proportioning valve, reman booster and master cylinder. I installed a filter in the vacuum hose and bought the vacuum block with the extra port. I installed new russell braided brake lines in the front but havent changed the rear. I bled the brakes like i read how to do. Now when i drive, i notice that the car is dragging. It seems that both front calipers are dragging in the front. The front rims get really hot and i see smoke coming from the front rims. Any ideas? I did change the pedal and put new brake fluid.
