OK my only input for this...You're running a 49
If I upgrade the Turbo it's a 44 or larger..ok back under my rock![]()
TE 44 and a TA 49 pretty much have the same internals TA 49 is stock appearing and TE44 is not.
Prasad
We use the 210-215 with awesome results, do a search under the Full Throttle 210-215 and read the results. I posted the combo we ran with that cam here few times . It is a proven cam and I'll definitely recommend it. I will also add ported heads, bigger turbo and injectors as well to your combo. There is more than one way to skin a cat but if the funds are available I will get everything done, right now you have it all a part and it's easier and cheep to do than later. This way you can blow the doors off not just his car but 99% of the cars out there. Just remember, there will always be someone out there that's faster than you no matter what you do, do not under estimate anyone!!
HTH
Prasad
I don't see anything in your signature about bigger downpipe, hi flow cat, cat-back exhaust! It don't matter how good the intake side is if the exhaust side is stock, you're not going to get max power!
Turbo's DON'T like backpressure!
Conrad Carter
I have raced a kb cobra at the track that was said to make 580 hp to the rear an killed him
Any of you big bad GN guys close to Florida? I wouldnt mind going against your invincible GN, money or for fun doesnt matter.. Just as long as we post the results in all these threads about mustangs...:biggrin:
You said you posted your results somewhere? Where did you post them and how can I find them I would be really curious to see it. thanks
-Andrew
