I had a GN with this servo,3-2 downshift was terrible. Thought it was gonna break something. I took it out replaced it with stock GN servo. Much better. I have sinced learned the big cushion spring should be left in. I am considering putting in my latest experiment.
Took it out tonite and noticed the big piston that sits in the cover only has the inner seal on it. And the little steel piston has no seal/ring on it either. This is exactly the way it came outta the trans and it worked.I just want to be sure it's okay before I stick it in.
Thanks:smile:
Thanks:smile:
