SignUp Now!the guy at autozone said was build to spec and said would have drain back in blockExpect it not to have an oil drain hole tapped, have three dot rods, non-rolled fillet journals, and cast/hyper pistons. In other words, mostly non-turbo parts.
1600Interesting.. whats the price on.it?
were would you recommend getting a engineTrust me, they lied to you. AZ has changed reman companies about every 2 years because of warranty claims. They won't build it to spec and you won't get the proper parts in it. Get an engine from a reputable member and you'll be fine. We've got several members that can help you. In case you're wondering, I used to work for AZ as and assistant manager and you really don't want a Buick from them.
And, valve geometery was all over the place......and I mean like .010-1.10 lash. Totally slapped together garbage.
