I am looking to get my 87 gn to hook. I pretty much am using stock springs front and rear,have a set of comp 3 way shocks front and rear,stock boxed upper and lower arms in rear, Front have upper tublers with lower stack a arms. i have a h and r rear sway bar on it. Now i am looking to launch off a trans brake come spring and hook the 700 foot pounds the lil baby 6 is putting out. So i am looking fo combos that work and work well.. if you dont want to post the secrets stuff up here pm me.
i was going to go with qa1 coilover conversion up front,and put in lower tubulars. And was thinking rears use qa1 coilovers 1n rear and buy upper and lower bars. So i am looking for suggestions on what seems to work arms in rear work,single adjust double adjust what.Also in shocks double or single adjustetc This is primarly a street car that i run once a month at some rsd. i use a 275 60 15 mt drag radial on a stock widen gn steel wheel. So please feel free to throw out there what works ... my goal is to hook and hook hard,i am doing all the body bushings,and doing driveshaft upgrades right now.
