turbo buicks
ESADAH!!!
- Jun 13, 2002
hey i was reading old posts about turbo 400s and thrust bearing failures. does this problem only pertain to those using transbrakes? if not, what would i need to tell someone building the trans to watch out for or do a certain way? i dont plan on using a trans brake and DO NOT want to screw up a brand new rotating assembly. also, i want to be able to put the car in drive and drive it around but also have the ability to up shift it manually (like the stock shift pattern), how is this accomplished? im not sure what all this reverse/forward pattern, manual/auto VB talk means either.
thanks
thanks
