T&D rockers for stage II heads higher ratios
norbs
Classic fast, XFI, SPortsman & MS3 programming
Looking for some TD rockers for stage II heads with some higher ratios 1.71 or even higher welcome!
I've got a bunch. Will have to check ratios though. Will be a month before I can do it.
Norbs. I have a few. but 1.65..
THey would be stamped S for 1.65 how many of of intake and exh do you have, they must have full threads in the adjuster for oiling through pushrod.
So before I go wasting my time looking for you a set of L or S rockers like you asked. Should I look for H rockers instead??? Just asking!! Mike
I need one L exh , and one S intake to finish a set, If you can;t find either a Full set 12 H's I could use instead as long as they for pushrod oiling.
I have the L & S and a set of H's. Your shims are in the standard mail (envelope) Mike
Mean Mike.......... BlownV6 is sending a completed set of rockers, however I would not get rid of your spare parts, they could come in handy one day...Thanks for your help.
Norb
